question about subs
liftednali
i am thinking of getting 2 12 inch subs with a amp anywhere from 560w-1000w. i have a 2000 Yukon Denali with the Bose system, im wondering if there is any way i can keep the stock system and just add the box to the back and hook up the subs to the aftermarket amp and factory head unit. would this work?
thanks
Bigsteve04Ho
Yeah you will just need a line out convertor to run your signal to the amp. Pretty straightforward install
L
liftednali
How would this be done? sorry its my first time dealing with this kind of thing. would it run from the head unit to the amp/subs?
thanks
Bigsteve04Ho
Yes what you do is tap into the speaker leads usually to the rear speakers since you probably mount the amp in the back. then the box converts the signal to rca inputs.
L
liftednali
okay, so ill mount the box in the back have the wires from each sub go to the left and right rear speaker as well as the line out converter and amp which i will mount under the seat?
Bigsteve04Ho
No the input to the convertor comes from the speaker leads, the box has rca preouts on the other end. Those plug in the input of your amp, which has outputs that connect to your subs
L
liftednali
Okay sweet i got it now, any specific converter you recommend? not too expensive maybe maximum of $40
Bigsteve04Ho
I think the PAC one is your best bet. Just google line out convertor and youll find it
bama8113
