Question about tail lights
lexustt
I have a 2011 tahoe and I want to order smoked stock tail lights but don't like the ridges that are on the tahoe. Would I be able to order the stick Denali taillights and install them with no problem?
Difference below in case I have confused anyone. It says in the link one or the other. Just want to make absolutely sure. If a=b and b=c than a=c lol
http://www.smokedouttaillights.com/components/com_virtuemart/shop_image/product/Yukon_or_Denali__4cd31ff736af2.jpg
http://www.smokedouttaillights.com/components/com_virtuemart/shop_image/product/Tahoe_or_Yukon_2_4cd33e8c626df.jpg
NathanJax
Vacation Nathan
Administrator
Jax, Fl
yes, the housings are all the same. You can switch them into either vehicle.
Escalade = Tahoe = Yukon
yates ™
Resident Apple hater
Iowa
yes you can switch them into either vehicle.
Escalade are not a plug and play deal also sometimes (Yukon lights at least) have different sized bulbs and different plugs.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
You know what I mean. The HOUSINGS are the same. Has the same screws, has the same plastic inserts you keep breaking...
KMeloney
You know that the Denali ones have a "ridge" on them as well, right? It's just that it's vertical as opposed to horizontal.
You can get smoked G4 LED lights that will be completely smooth...
yates ™
Iowa
I know what you mean but also it is not the only factor he needs to watch out for, if he gets the different taillights and not the sockets/harness they will not work.
L
lexustt
Thanks for all the input. It's the horizontal lines I don't like. Are the bulbs and connectors the same between the tahoe and Yukon?
yates ™
Iowa
Not necessarily I bought a set of lights and the bulbs and sockets were a different size but the seller was nice enough to send me the wiring harness for them, both 07 Yukon SLT's BTW
Igot26s
wise words
mitchellowen
