I just finished installing a backup camera on my 2001 Yukon. (installed 3.5 monitor in OnStar cubby hole)... I wired the camera & Monitor to the reverse wire. All works great.
One issue, I mounted the monitor upside down because that is the way it fit best, the monitor has a rotate screen option, so I was able to rotate the picture so it is right-side up.
The problem is that every time The monitor turns off by either putting the truck in drive or turning the truck off... The next time the camera turns on, it is upside down again. Seems as if the monitor is not holding the settings, could this be because I need a constant power to the monitor and can't install thru back up wire???
Any suggestions on how to rectify?
Thanks
Thanks
