Question on doors
Tbruz
Windham NH
1997 Tahoe 2 door door replacement question.
Are the doors of a 2-door Tahoe unique or are they the same as a Silverado pickup truck?
Curious as to any options available to replace a door on a 2-door.
Thanks in advance
Tbruz
Multnomah Falls
According to GM Parts website the shell and outer panel for the driver's side door are the same part numbers BUT I would double check to be sure.
A salvage yard should be able to tell you as well.
T
Tbruz
Windham NH
Thanks PNW...follow up question are 4 door Tahoe front doors the same PN as 2 doors?
Thanks again.
Tbruz
Multnomah Falls
Yes, as far as I could see but double check because that year and 2 door info is limited.
T
Tbruz
Windham NH
Appreciate everyone's help on this.
Just reached out to a Texas Junkyard for a rust free door.
Thanks again
Tbruz
exp500
Yes, 4 doors are same.... But different... Trim and wiring/ window switches. Try Car-Part.com yard listings.
Multnomah Falls
Yea, everything I found about 2 door and 4 door said that the fronts were the same but again, I did not trust my searches completely as gospel. Glad it worked out and hope you get what you need at the salvage yard. Great time to put in new hinge pins and bushings.
Also good time to inspect all wiring in the convoluted tubing where all the wires run.
stevedonato
will 1998 silverado extended cab driver door fit a 2000 silverado extended cab driver door?
FYI I can't find out how to POST a new question/topic on this forum?
Multnomah Falls
Go to Forums, scroll down to the correct year section and then open up the sub section of where you want to post and then at the top right it says, "Post New Thread".
blanchard7684
