Quick fitment confirmation question (GMT900)
DB1337
Hello guys, just getting straight to the point so as not to waste any of your time, the donor vehicle is a 2007 Escalade ESV and the receiving vehicle is 2014 Chevy Suburban RWD LS.
1. Will the rear bumper fit?
2. Will the running boards fit?
3. Will the windshield fit?
4. Will the curtain airbags fit?
Thanks in advance :)
Welcome to the Forum from NH.
Pics of the truck, please.
D
DB1337
I hope to provide as much as I take in terms of knowledge, I love a good forum so participating more will be right around the corner for me hopefully. Anyway thanks for the help so far!
I will make a thread about my truck and it's story soon later today. As for the donor Escalade ESV, it's a junkyard car that's a dozen miles away so best I can provide for now is a VIN: 1GYFK66877R429155
D
DB1337
As for the pics:
So my vehicle was involved in an accident on the interstate that involved my Chevy flipping over on an embankment and hitting an overpass support. I'm in the process of fixing the it, here's my list of things that I've finished and things that I still need to do.
Finished:
• Replace hood
• Replace passenger/right fender
• Replace back glass
• Replace rear driver/left glass
• Replace intake manifold
• Straighten frame
• Replace head gaskets
• Replace dipstick
• Replace throttle body
• Replace vacuum lines
• Replace coolant hoses
• Replace radiator
• Replace radiator support cushion
• Replace pass/right headlight
• Replace driver/left taillight+bulbs
• Replace coolant tank
• Replace inlet duct
To be done:
• Replace driver/left fender
• Find a tiny vacuum leak
• Replace curtain airbags
• Replace windshield
• Replace/fix seat belts
• Fix rear driver/left quarter panel dent
• Fix many scratches
• Replace rear bumper
• Replace driver/left running board
• Fix front driver/left rim
So I'm almost done, hopefully, it'll be on the road soon and under $1500 in the repair.
Sad to learn that you were in an accident but love that you're getting her fixed up and back on the road.
I believe everything will fit.
What I suggest though is to plug both VIN numbers into GMPartsGiant and maybe ACDelco https://parts-catalog.acdelco.com/acesCat.php to see if the VINs use the same airbags.
The rear bumper cover on the Esky may be slightly different but it will still bolt right up if it is.
How did you and the passengers if any make out?
RST Dana
OH
Not sure why you got a straight no
the actual metal portion of the bumper should fit
running boards should fit
windshield should fit
airbags "may" be different, you would have to look at them and compare them it's not uncommon for those to change design for a variety of reasons
why not?
My bad. My brain saw 07-k2 not 14. Lol
D
DB1337
Thanks for the resources. Will look into them.
I was the only one in there driving, I made it out just fine, nothing serious. The guy who hit me (tiny impact which caused that) was also uninjured.
kbuskill
NE. FL.
Rear bumper cover from Esky ESV will definitely fit. I have one on my Burb.
Everything else will also fit with the exception of the airbags being a maybe but my bet would be that they would as well.
dabsnabbs
