Rad Fans run with no key on cold engine
ferrelbirdjr408
I've been working ******* my own projects but here now so sorry. It sounds a lot like you have a current draw problem? Your cooling fan relay may be shorted and keeping your fan on. You can check this out by testing your connections at your plugs at the fan (s) itself with the ignition switch off and no power on at all.
Sent from my SM-T580 using Tapatalk
OR VietVet
Multnomah Falls
Military
Willamette Valley
He already did a bunch of relay swaps that did not fix but may not be the same relay you are talking about. I did ask a couple days ago if the problem is fixed but no response as of yet.
ferrelbirdjr408
No I didn't mean test the relays test the harness from the relay to the fan or fans this way you would know if any current is passing through the line and it is constant measurement while the ignition is off. Then test the connection for the relay plug in at the fuse box without the relay in its place with the power off then turn the ignition on. And testing proper measurements of voltage.
OR VietVet
Multnomah Falls
Military
Willamette Valley
Well, it has been almost a month since we last heard. I wonder if this problem got fixed or not. Sure would like to know.
W
wifes_truck
Hi all, sorry for never replying back.
Yes and NO... it did fix it... but then the problem returned about 3 weeks back.
So, to fix the problem, took apart the wires for the unit, stuck a hair dryer down in there for about an hour, siliconed back up the seal after smothering the connection pins with electric grease.
so, that was the problem. and yes it has resurfaced...
cheers
just a bad design on chevy part i am thinking.
