Radar Detector Direct Wiring
Bam
Abilene TX
I just finished doing this. I don't have an ******, my radar detector has a normal cigarette lighter adapter instead of a phone chord type. But this works the same. I cut the adapter a few inches back from the end that plugs into the detector & spliced the hot & ground to the appropriate wires on my mirror harness....Works like a champ!
Edit...If you are going to do this, you might want to leave a little more wire than I did. If I had kept it longer I could have run it up the harness and tucked it in the headliner. Didn't think about it until I had already made the cut...oh well...It doesn't look bad, but if I had done that it would have been cleaner.
stevek
Dallas, TX
You don't have to splice into the harness, you can get some crimp pins and plug them into the actual plug... invisicord essentially
Bam
Abilene TX
yeah...I realize that. It was kind of a spur of the moment fix using what I had in my garage.
My radar detector had rechargeable batteries in it to make it cordless (plug in to cig lighter to recharge). Worked great for a while until today.... I went to pick my son up from school & realized the batteries weren't holding a charge. Turns out that the sun beating through the windshield had melted/ruined the batteries. I could replace the batteries, but I knew this would be a recurring problem, so I figured I would go ahead and wire it in.
Since my young'n has some tooth fairy money burning a hole in his pocket that I dont want him to spend yet, I knew it would turn into an all afternoon event with extra stops, or much complaining if I took him downtown with me to buy some crimp pins..so I just went ahead and tapped into the harness. Oh well....got my 12v...got my ground...same same... :)
mcguire7
