Radiator Change
willua11
Alabama
Has anyone changed out a radiator on a 5.7L? If so, how long did it take? and does it require "special" tools?
W
retorq
Kingman AZ
No special tools, could take 10 mins could take 3 hours depends mostly on you and your truck.
Sekani's 96
MA
It's actually pretty easy an make sure u buy 2 ctn of dex cool antifreeze, max time should take u 3 hours there's a video I found for reference if I can find it I'll post the link later on
Sent from my iPhone 4S
BattelWagun
Chi-Town USA
It's not a hard job, just make sure you drain tyne system before removing the rad, makes it a LOT less messier.
ezdaar
Chat Troll
Redneck central, Aka Houston
Buy the Correct crows foot wrench for the trans cooler and possibly power steering cooler lines. Or risk stripping the cheap pot metal ends..
Torque load the wrench with one hand then give it a good hit with other hand to break them loose.
If you use the gradual applie of pressure, even with the crows foot wrench they have been known to strip out.
WalterMitty
Oklahoma
I have changed two. It's very doable with common tools. I usually service/replace related items when I do it. Hoses, thermostat, water pump and accessory drive belt.
bowtiefreak
No Quarter
Near Philly
real easy, seriously. take your time and do it while it is light and you'll be cool...haha I couldn't help it
blueshroom
