Randeez 2012 Budget Yukon Denali Build (stick on hood scoops galore)
randeez
randeez
south florida
in the mean time.... im going to pump out the fuel tank and check/clean the fuel filters on the big pump. still ****** around with the coolant system. was good for a while, since running ac fulltime it seems to heat up, tried that restrictor in the hvac hose didnt do much...i cant fathom how there isnt enough air flow going thru the radiator when im going 80mph. so going to take the heater loop back out and drive around a few days and try to figure out wtf
wjburken
Eastern Iowa
Check out this video. He gets into the aerodynamics of pressure differentials over radiators and other heat exchangers.
randeez
randeez
south florida
I will here in a bit when I get done, ice already went back to the simplest set up possible.
Pre fuel filter looked good, caught some chunks from hoses and drilling out tank probably but other wise clean. Post filter was collapsed, ill take some pics in a min. Had a whole nother filter and housing cause summit sucks and I ordered the same order twice. Never sent anything back so worked out I guess lol.
randeez
randeez
south florida
Hell yeah!! Back to the track!!! [emoji16][emoji106][emoji631][emoji631][emoji631][emoji631]
i think wednesday is open to slicks and drag radials, now that i have some....heard you can usually get a bunch of runs in also so will prob try and get out there then. going to revisit front straps and see if i cant come up with something
need to change the oil too
raceguy13
