Randeez 2012 Budget Yukon Denali Build (stick on hood scoops galore)
randeez
randeez
south florida
Belt problem resolved? Meh. Now this thread is gonna be boring.
You on corn or race gas?
57% ethanol iirc... put some 93 in it to help fuel pump and injectors a little, but cost me a couple degrees of timing. i think in the tune ive got the cutoff at 60% before it drops timing. everything from there up runs the same timing
randeez
randeez
south florida
there is another "event" tonight - 28" tire shoot out and a street car shoot out, they wanted "hard tire" for the street cars but dude told me they would let me run with the nitto drag radials. usually up to racers to agree with it tho. i kind of want to go and make a couple passes with the front straps tightened up and see if it helps dont care so much about racing but if theyll let me run i may head out there
Could you run avgas to keep your timing and give 'er the beans to see what she has?
Or are you after your best ET on pump gas so that'd be irrelevant to you?
It could be worse anyway since you'd lose the cooling benefits of the alcohol.
randeez
randeez
south florida
could use racefuel but its more of an ET as driven on the street for me. ms109 per 5gal is like 80bux iirc...so spending 160bux just to make a couple passes isnt really worth it for me. do that a few times and i wouldve just paid for injectors. a lot of race fuels are oxygenated also, so you dont gain much going from e85 to them
Speaking of injectors, @Tonyrodz has a question about some he’s looking at buying, over in his build thread. I used to have a link with all the ls based injectors but can’t find it now. Do you have a site where you get your info on them? All I know is the tune needs to be adjusted if you throw bigger ones in, at least that’s what I was told by BB.
randeez
randeez
south florida
i think ICT billet may have a chart on their website of all of the injectors, sizes, part nos
also...one of my wastegate tubes has broken (separated cause ****** weld job?) halfway off the merge pipe lol. i made two runs last night first one did 141mph, second one was like 137mph... i didnt think much of it but the second run shouldve been better and now i guess i know why
Fless
Super Moderator
Elev 5,280
I checked out both those sites earlier, can’t find the ones he’s looking at, 17113553. They show as AC Delco OE for 99-07 4.8, 5.3, 6.0 Chevrolet when I Google that number.
Dflo92
