I have a mini grill loli have had it there before, it just takes a beating and ends up leaking after a month or two from taking rock hits
WTFWelp...I forgot step 1
Always double check every mf thing you buy cause there's a chance it's ****** up
Orifice tube, came assembled, with an arrow on it. Figured it'd be pretty hard to mess up, arrow going the wrong way blew the orifice tube into the hose. Might be why I'm having ac problems flooding the compressor. Fans already in tho may pull it forward, put trans cooler back where I had it and and blow thru all of it.
I was real close to not even changing the orifice tube also
yup pretty much what i said when i pulled it apart.
Front diff mounts making noise?well...ac definitely works hell of a lot better, chiller gets water temp down into the 40s in a few minutes. cabin ac blows ice cold, refrigerant pressure still jumps to 300psi or so after a long drive and then sitting in traffic. i kinda wish one of yall would/could log what it does normally, cause i think thats just what it does.
the pusher fan slows the ECT rise while the pressure is up there. seems like i can drive it comfortably with ac and chiller on ect will stay around 200*, in a little traffic, couple stop lights temp climbed to 214 before i got moving again. i have it installed in about the worst way - its against the trans cooler but the top 4" and the bottom 4" blow by it and are 2-3" from the condenser. could definitely be better but would of had to redo everything up front to make it good.
started making some crunchy axles noises again, only under hard accel so not easy to pinpoint. jacked it up wiggled some axles, passenger side felt "looser" so i swapped it. the axle i pulled out didnt look too bad on the inner joint not sure about the outer. the limiting strap clevis that goes thru the shock tower threads got ate up and i had to cut it off. that side was right under the downpipe so i couldnt really tighten it much anyway. i need to come up with a different way to hang that side.
still makes noise so i ordered another axle to swap in the driverside, but im almost wondering if its in the transfer case. i "feel" it at my feet when its starts clunking so im pretty sure its the axle, itll be here in a couple days and ill swap it.
other than that been running pretty good, doesnt seem to be pushing any air into the coolant system, waste gate dumps out the hood are annoying af, since ive been driving it a little i really want to gear it back down.. at like 90mph its turning about 3000rpm![]()
ill take a look at them, i replaced them not many miles ago thoughFront diff mounts making noise?
Just thinking…ill take a look at them, i replaced them not many miles ago though
Does that make a clunking noise at your feet? I've had that with the avalanche for years. Could see or feel anything loose in the front...Front diff mounts making noise?
I will try and get time to see what mine does. I'll note, driving mine across country a few weeks ago, we would drive 200-250 miles and take a break. Every time we stopped while getting off the exit ramps, my cooling fans were on high, like as soon as it slowed to 40mph approaching the stoplight, fans were on high and stayed high pretty much all the time during our short stops. On the highway, they were off and nothing ever got hot. Maybe the pressures get high like you mentioned above.well...ac definitely works hell of a lot better, chiller gets water temp down into the 40s in a few minutes. cabin ac blows ice cold, refrigerant pressure still jumps to 300psi or so after a long drive and then sitting in traffic. i kinda wish one of yall would/could log what it does normally, cause i think thats just what it does.
