randeez
yukon is officially 2wd, np261 slapped right in, sorta. its a little more girthy than other t-cases and i had to pull the aux fuel pump out cause it was in the way trying to spin the front drop up. after it was up fuel pump went back in no problemo.
left front driveshaft out, removed CV axles. and took it to put 140bux worth of 93 in it, it was very empty, i had been sitting and tuning the idle while it hasnt moved so it took like 24+ gallons to fill.
need to get the ac lines back together and recharge it, its hot out, then rain, then ******, then hot...fkkin florida.
going to order a few parts to rebuild the rear end then drop it off to buddys shop. may wait a few weeks. i been spent some money last couple weeks that i kinda forgot about
I hadn't heard about new motorsports park, I'll take a look!We heard today that a new motorsports park is in the works, Atlantic Farms Motorsports is going to build a 900 acre complex with a drag strip among other tracks.
What do have to replace on the rear axle?
but grill, trunk and handles I will >> color match <<Little more tuning on yukon...trying to get it to "flare" when starting just to get everything moving. Seems to want to start then drop rpm immediately and it kinda want a to bobble.
Ctsv - we need to figure out what to do with boys.
The chrome crap around the windows, grill, trunk, door handles
All I ever see is blacking it out, and I don't like it. Around the windows black is fine, but grill, trunk and handles I'd like to color match.
Then get wit it.Ctsv - we need to figure out what to do with boys.
Looks tiddies, but no pics....?dropped the sway bar a couple inches with some drop brackets made for a 90s bronco, they move the bar back about an inch, bought some shorter bolts for the endlinks (3/8x10" grade 8) cut down the sleeves and it all fits up pretty nice.
ordered another exhaust crossover "kit" from trickturbo to have someone who knows how to weld, extend it down to match the sway bar to clear the front driveshaft.
finally got a tracking number for RCV axles! and theyll be delivered tomorrow. i thought i saw someone else on here with them? hopefully they got everything right, mismatched mounting, and different lengths lol. hoping they live up to the hype cause they were expensive enough. prob going to put the np149 back in, its been sitting on bench rebuilt, new case half, new chain and gears, should be pretty fresh.
i rolled the rear axle pinion up a little with the spohn bars, i left it alone when i put on the lift kit and it was about dead level, i put a couple degrees in it on the top bars, it was still pretty centered so i didnt touch the lower bars.
with the maf in it, its been idling good no problem with ac. kind of almost want to put the A2W back on and just put some length in the charge pipe (and maybe size it up to 4") and run it. but for now i will just see how it does.
need to call my shop guy and see whats up with getting the right axle in, ive got a set of 4.10s and the install kit ready. if he cant get another axle will prob just order the locker and have them rebuild mine.
not sure if i put it in here somewhere but front belltech lift coilovers are in, front sits a hair higher than the back, but it turns full lock both ways, doesnt rub, looks tiddies. needs an alignment still
X2Looks tiddies, but no pics....?![]()
