Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
For some reason my truck idles high at random times and I have no idea what is causing this. It idles high and sounds like a big fan blowing. So if anyone has any ideas to what is causing this let me know.
it could be the ac compressor... even if your ac isn't on, these trucks keep it cycling, this could what is making your engine rev up, when the compressor kicks on. Is is at random times or is when you first start it up??
That's the clue right there.
When you first start up everything is cold, including trans oil. Next time when it happens, watch your rpm and the speed reading. Your rpm is probably higher than what it should be at that speed. The tranny is not shifting up and keeps the engine rpm high until the temp goes up little. I bet that doesn't happen on already warm/hot engine.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
