Ok so when I bought the truck a few years ago I would randomly get a p0300 code I'd feel it occasionally but not bad enough to be concerned. Plus I had alot of other repairs and maintenance to do. Well when I got my truck back from the trans shop I noticed the miss alot more and it's been consistent sence then. So I bought plugs and wires. Both acdelco and yes I used the iridium plugs according to the tsb. When I pulled the plugs the previous owner put autolite double platinums in it
Also I found that cyl 1 was loose which scared the crap out of me. But luckily it tightened up just fine. Unfortunately even with the new plugs and wires I can still feel the misfire. I'm gonna try and put my bosses scanner on it today after work to see if there's any codes in it anything else I should look for. Also some info for you guys. I've already replaced fuel pressure regulator, intake manifold gaskets, oil pressure sensor, camshaft sensor, valley pan gasket, knock sensors and harness, valve cover gaskets and grommets since I bought the truck. Ik there's a relearn for the crank sensor. Is there one for the camshaft sensor?
