bigskinney
- Joined
- Feb 18, 2025
- Posts
- 3
- Reaction score
- 0
2021 Yukon Denali 6.2 premium pkg. steering randomly refuses to unlock. Motor will start, transmission works, no binding in steering linkage . no error code ( I have code reader) disconnecting battery doesn’t help. The first time it happened I kept starting and stopping engine and opening door so that solenoid would engage and disengage. It finally , reluctantly, partially disengaged ( I could still feel the tip of solenoid rubbing against locking plate. After a few more starting and stopping that rubbing went away and everything seemed normal. Two days later it did it again. I removed steering wheel trying to find locking plate (like on older models) but discovered that it had been re-engineered. Since it had locked up in mall parking lot I reassembled it so I could get it on a rollback but lo an behold it had unlocked itself. I cannot discern which fuses control that module or even if it would run if I could find the correct ones. Is there any way to disable it . I enjoy some of the new electronics but really miss the days when I could fix Anything that broke.
