Rattle behind rear headliner
phileaglesfan
Utah
There is a semi-loud rattle behind the rear headliner right above the rear window. Does anyone know how to get the headliner off. My daughter sat in the 3rd row seat on the right side and the noise was right above her. We can hear it from the front so it is annoying.
timhbo
check the rear pillar
I had the same issue and thought it was in the headliner/window. it was actually the plastic pillar piece on the back of the vehicle. take the tail light off and get some sealant to place inside the pillar. I used weather stripping and an old pair of sweatpants. sounds funny but it worked!
Modded
That Guy
I was about to say the same. It is more than likely the long plastic piece above the tail lamp called an applique.
Happened to me too. Got it fixed for free at the dealer under warranty.
P
phileaglesfan
Utah
Thanks I'll look at the tail light/rear panel area.
My Denali has 44k on it so the 3 year warranty is over.
P
phileaglesfan
Utah
I think I found and fixed the problem. Upon removing the rt tail light assy I noticed it was a pain to remove after I took the two screws out.
I looked behind it and the top mount was broken. Finally got it off with some light convincing and reglued the mount back to the assy. Reinstalled, took a drive and didn't hear a thing. I'll keep an eye on it to see if it comes back.
ericjvasil69
