RBP Grille Help Please!
Turbo24
hey guys, new here. my girlfriend has a 2008 denali and just ordered a RBP grille for it from carid.com.. well she got it a few days ago and there are no instructions!! normally i'd be patient and try to figure it out myself but she came to wyoming to visit and going back to colorado for school so i have to have this figured out by monday. i called carid and they were no help whatsoever, RBP is closed of course so im out of luck there. can someone PLEASE post instructions/ a how-to so i can have this done for her. it would be greatly appreciated!
NathanJax
Vacation Nathan
Administrator
Jax, Fl
moved you thread to the 07+ section :Handshake:
Per RBP website:
Relax. Installing a new billet grille on your vehicle is easier than you think. If you know how to use a screwdriver and a ratchet wrench, you have just what it takes to mount most billet grilles.
Billet grilles can be divided into two categories based on their installation type: bolt over billet grilles and replacement billet grilles. Let's take a look at how they work.
Bolt Over billet grilles
These billet grilles are the easiest, least time-consuming to install. Rather than completely replacing your existing grill work, a Bolt Over billet grille sits right on top of your existing one. These have pre-attached hidden bolts and use brackets and locknuts for a solid, secure and simple installation. They require no drilling or cutting of any kind.
Replacement billet grilles
Unlike a Bolt Over billet grille that sits right on top of your stock grille, a Replacement billet grille is a complete transformation. Everything that your auto manufacturer installed in the grille section will be taken off in exchange for your personally chosen new billet grille. This means that you will have to perform a bit of bodywork, but it is not as bad as it sounds. Most stock grilles are mounted by plastic brackets, so all you have to do is slice through them with a saw, which should take no more than 20 minutes.
Once the original is out, your new Replacement billet grille takes its place. On certain vehicles, some easy drilling might be needed. Although the Replacement billet grilles take longer to install, the final result makes the time worth while.
T
Turbo24
i appreciate it. kinda looking for a little more info though. i found how to do a 2011 denali hd but im pretty sure its quite a bit different
Yuk0n07
I have a feeling the process would be pretty close tho, have you removed the grill yet?
Regency
Please take pics I bet it'll look :boobs:
T
Turbo24
ive been a mechanic 6 years and working on this new denali kinda has me stumped. i havent even completely figured out how to take the grille out! there will be pics to follow. today i took the chrome off of the RBP star for the grille and now its hot pink, i also pulled the bumper grille off and did that in black.
T
Turbo24
Can someone give me a run down on how to take the grille out? I have to have this all finished by 3 today :/
Alsherooqi
