Really bad swaying from side to side help
humbo
Here are the readings that were out of spec on the 03 Denali
Left front toe 0.51 degrees
Right front camber -0.5 degrees
Right front toe 0.37 degrees
Total toe 0.88 degrees
Steer ahead 0.07 degrees
all was fixed. Handling now more predictable but not as firm as I want it. Will change out shocks and springs and get rid of autoride. Panhard rod I see is from QA1 and another from Spohn Performance. Any recommendations? They are both adjustable.
OR VietVet
Multnomah Falls
Military
Willamette Valley
Use whatever panhard appeals to you. I have no preference except that is adjustable. I would replace that before the shocks and springs and see how it does and put polyurethane bushings on all sway links and frame bushings if you already haven't done that.
Dave6137
