rear air bag?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
There you go. Just move it over then should come down
K
kwb0748
Do you need mean move the sway bar? And if so. Do you have instructions to do so?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Google djm rk2007 instructions. Look at page 2 it's all there
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Yes move over and drill holes.like instructions show
K
kwb0748
After moving the sway bar, it looks like the Panhard bar bracket on the Dr side of the axle is hitting the body mount cross brace.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
at ride height will all clear. SO when you drop the truck down the swaybar should be moved over 1.5 inches because the enlink with more twist goes there plus your swyabar sits on the outside of pass side endlink
K
kwb0748
Yea after the move the sway bar isn't hitting anymore. It's the Panhard bar on the Dr side on the axle, the mount hits the cross brace for the body mounts.
NickolausC
