Rear axel swap
Donnie Yukonie
Yates Caretaker
I doubt you will find a Dana 60 for $200 dollars. cheapest I found them ran $460 and that was for a Junkyard one . 14 bolts Go for the $200 dollar range another thing that sucks about Chrysler axles like the 60 and 70 is parts for them are Way to overpriced because the Jeep guys demand them . Also most GM guys choose the 14 bolt over the 60 or 70 for mod reasons. You might have to get a custom Driveshaft made , Spring perches relocated , brake cable and lines swapped Ect... this all adds up and in the end a 14 bolt is just as strong FF of course
@NAK My comment about the 14 bolt SF not having as much after market support is when it is compared to its FF cousin. The market supports the FF more for selectable lockers , diff covers and chromoly parts ect... Actually only in the recent years have Disk brake kits been available for the SF axle more so than the SF for the simple reason that Most guys that do build a Beast off road machine will chose the FF just for strength and reliability reasons . the pinion support and Non C-Clip design makes it a lot more dependable and easy to repair on the trail Apparently the FF can handle about 6,000 pounds of Torque at the Pinion because of the guard . this reduces the amount of deflection in which we know causes most grenades other than the Common G80 issue.
@Kon99 - The 5 lug Version of the 14 bolt came equipped to the 454 SS truck in the late 90s at least thats the only vehicle Im aware that came with one . I can't confirm this for sure but apparently there are Kits to swap a 8 lug to 5 lug How much it costs and the labor it takes Im unsure
@ symba
Depending on which route you decide to choose ,
any 14 FF will swap over from the 90s Just keep in mind this will require some minor modifications .
the Semifloat is a easier swap and only requires a conversion U-joint Neapco #1340 I think the part is (ill confirm this later) Other than that as long as you got it out of a heavy half ton (2500 with either the 6.5TD or 7.3 Gas) 4wd the swap is just bolts . the existing brake cable is the same size ect... the only models you have to watch for is the C&C (cab and chassis) and Van models . I believe the Van models are 2 inches wider
mattluttrell
Naw, I only mentioned the Dana 60-80 because they are $200-$300 all the time here on CL.
http://oklahomacity.craigslist.org/pts/4386792931.html
Your other points are valid. I think we can all agree that if you're going to be swapping axles you should probably learn to weld sway bar mounts, shock tabs, etc.
Additionally, these generally get out of hand real quick with regards to price if you start building. I'm on of those jeep guys mentioned above.
The 14 bolt really is the best bang for your buck if you don't care about clearance issues.
Symba_The_Lyon
Symba_The_Lyon
So do any one know what year of chevy trucks have the 14 bolt Semi Floating Six lug axle ? I know that 1993 GM offered a light-duty 3/4-ton truck that came with a 14 bolt but is there any newer years that would fit with very little mods?
aj713
Jersey
I'm interested in the 6 lug version too, now that I'm thinking of keeping my 95 2 door lt version.
Sent by carrier pigeon
Nak
The 14 bolt SF 6 lug is extremely common on 1/2 ton suburbans. Look for the RPO JB6. I just finished this swap a bit ago...
Avoid the factory posi. I looked at 6 rear ends with the G80 posi, every one was bad. Several wrecking yard guys told me they'd never seen a good used G80.
The main weakness of the 14 bolt SF is the gear carrier. An Eaton Trutrac will fix that, but is spendy. Outstanding posi though, and cheaper in the long run because of no clutches to wear.
The SF has better ground clearance than the FF, the FF is stronger. The SF is MUCH stronger than the 10 bolt, and much heavier too.
You'll need the U bolt backing plates from the donor vehicle, the plates that go on top of the springs. Your current U bolts will work fine.
If you have a 4WD, you MUST get a rear end from a 4WD. The 2WD version is narrower. The 4WD is 67" wheel mating surface to wheel mating surface.
If you have an OBS, any OBS will work as a donor.
The brake lines and parking brake cables will hook right up.
You'll need a conversion U-joint. Your current drive shaft will work just fine.
Get the brake proportioning valve from the donor vehicle. It'll need to have the same ABS setup as yours for it to work. If the ABS is different, find a Brake proportioning valve from a JB6 vehicle with the same ABS as yours. And yes, the proportioning valve can be removed from the 95-99 ABS units. They look to be integral, but they bolt on. If you don't swap the P-valve, more properly called the combination valve, your brakes will be dangerously out of balance.
If you have the '95 - '99 4 wheel ABS, the P-valve is still available new. If you have a '92-'94, then used is your only option. :(
The 11" brakes on the 14 Bolt SF are a HUGE upgrade over the 10" drums on the 10 bolt. Not just size either. The 11" brakes are duo servo type, the 10" are leading-trailing type. IMHO, the best brake upgrade you can make if you have 10" rears. My brakes went from crappy to outstanding.
If this is really just for the weight, it's easier & cheaper to bolt 100 pounds of lead into the cargo area. Or go with a custom rear bumper. A good posi will make more difference than the weight.
Donnie Yukonie
Yates Caretaker
Wow If your finding them that cheap you need to start a business , I know location matters but the CHEAPEST I seen a Front D60 go for is almost double that in the same condition
Hmm In all the information Ive ever read concerning the Swap Never have I heard about swapping the P-Valve? Is this a concern If I have my ABS unplugged anyway?
inthechateau
Maryland
You can get a 14 bolt 6 lug out of any Z71 silverado or Sierra. But it will be the light duty 14 bolt version.
Nak
If you've switched from the 10" rear drums to the 11" rear drums it's incredibly important. Even more so if you've disconnected the ABS. Most of our trucks came with JB5 brakes. That includes the rear 10" drums. The switch to JB6 brakes changes two components, the rear drums and the combination valve. The duo servo 11" drums are considerably more powerful than the 10" leading-trailing drums. If you don't change the C-valve, your brakes will be biased dangerously to the rear. Especially without ABS. ABS can hide the problem in many circumstances... The danger is that your rear wheels will lock up before your fronts. When that happens, your rig will want to swap ends and end up in a spin. ABS hides this by preventing rear wheel lock up, but it's a band aid fix to the problem. The proper fix is exactly what the factory did: change the C-valve to one with less rear bias.
People don't see this problem when they improve their front brakes. If the front brakes lock up first, the vehicle remains stable. Improve your rears too much and you create a very dangerous instability, unless you take action to re-balance the system. Balancing brakes is beyond 99.9% of us, so the proper solution is to use the factory specified hydraulic components. In the case of JB6 brakes, we're lucky that the only change is the C-valve.
If you swap other components like swapping to a different type master cylinder or rear disc brakes, you'd better be able to balance the system, or mimic a factory configuration.
Donnie Yukonie
Yates Caretaker
Cant you just Adjust the rear drums "loosely" to compensate for the extra Brake pressure? Im not calling you out I just don't see how the rear would be able to overpower the front unless you messed with the pressure system in some way . Ill definitely look into this and thank you for your information
mattluttrell
This is a real risk. I've converted a rear drum axle to discs. It can male it hairy. Brakes are often over looked and under valued, yet brakes can make a huge difference in most accidents.
johnnnyb63
