Rear axle shifted back with 3" block kit. 99 Yukon Denali
LuckyTuck13
LuckyTuck13
Thanks Jerky Arm Ape! I've been slowly working on the problem. And originally the rear axle had moved back about 2 inches with the 3 inch blocks. I got out there yesterday and cut the blocks to 2 1/2 inches and now that moved the axle forward 1 inch. So It looks like every half inch of block throws the axle back 1 inch. My leafs are rather worn out after 170,000 miles so I will most likely just replace both rear leafs. I'll try and post up a pic in the next few days.
Donnie Yukonie
Yates Caretaker
If your replacing the leaf pack it will bring it up a bit just because of the wear, I also second a AAL . Mine didn't really get to bouncy but for 3 inches you could shackle flip as well
DallasTahoe
I've been searching and I can't find anything, but on a shackle flip, is it just for the back shackle or for the front one as well? I really want to do a flip as opposed to a block, but I only want to add about 3 maybe 4 inches which is better?
wfstewart
