Rear Brake Dust Shield
mmeachem
I have a 2000 Tahoe, and need dust shields but can't tell if it's one or two piece. Any help?
The original ones are one piece. The 2-piece ones are direct replacements that are designed in 2 pieces so you don't have to remove the axles to replace them. The original design was stupid because of this reason. I used the Dorman 2-piece ones and they were pretty easy to install. If you buy the 1-piece ones be prepared to spend the whole day installing them!
mmeachem
mmeachem
Thanks alot for our help
You're welcome. The 2-part design really helped me to be able to do this. You will need a pair of good tin snips to remove the old ones. They come with pretty good instructions, at least if you get the Dorman ones like I did.
jcevans7
Friendswood, TX
I second red rocket get the double. Unless you like the jerk in off with sandpaper cause that is the experience you will get.
Sent from my SM-N910T using Tapatalk
emfadz
