David Kriss
- Joined
- Nov 20, 2017
- Posts
- 36
- Reaction score
- 32
I have a 2001 Yukon XL SLT that has a problem with the driver's side rear brake. The rear bakes are disk with drum parking brakes. The bake pads ride in two thin metal pieces that fit between the pads and the brake frame. The lower metal piece keeps breaking. The piece come in the hardware kit and I've tried kits from Auto Zone and the dealer. I have had the rotors turned. I've also made sure the metal pieces are firmly held in place by their tabs. The piece keeps breaking after a couple weeks of driving. I can tell when they break by a rhythmic scraping when the brakes are lightly applied. This rhythmic sound leads me to believe something isn't straight. That is why I had the rotors cut. This morning I raised the back of the truck and removed the tire. I started the truck and put it in gear. When I looked closely at the center of the hub and I can see that the hub isn't centered. Between this and the scraping I think the axle has a slight bend near the hub. I looked online and I see that replacing the axle isn't hard but at over $200 for the parts, I don't want to do it if it isn't the problem. Could the problem be the axle or am I missing something else?
