Rear camber issue
Turki
Hello, I have a negative rear camber
camber on one side of rear axle (the rear right wheel at the top).
I attached some pictures here.
Any idea to solve this please ?
rear left (no problem)
rear right (negative camber)
GMT800 SUV/Trucks
Welcome to the forum from Oregon.
How about sharing the year, make and model.
Since you do not have rear independent suspension I can only assume you may have hit something and bent to where the wear is being caused. You may also have a bad bearing or bent axle hub but since the axle hub spins, you should feel a wobble at the same time. You need to get the rig on an alignment rack and get a printout of the OE specs and what the readings are at this time. It could be a tire problem and not the suspension. Is this a tire that recently was rotated to the rear? Maybe problem is at the front if that is the case.
T
Turki
Thank you! , I appreciate your welcome and reply, I did rotate but the problem was before that.
The car is Yukon XL SLE 2017.
Bill 1960
Testing the Limits
If it wobbles as it rotates it can be a bent wheel or a bent axle shaft.
If it doesn’t wobble and the camber is off you have a bent axle housing.
GMT800 SUV/Trucks
Did you hit a curb or did anyone else driving it hit a curb or a large pot hole? Again, an alignment readout will help decide what is wrong and what to look for.
SuitedSevens
