Rear Defroster Ripped Off???
Ponchonutty
New Washington, Ohio
After buying 2 kits and trying to glue it on 3 times I gave up and bought a new piece of back glass from Safelite ($229). Expensive, but I don't like broken things on my truck. The tab just kept popping off with the glue. Even when it was on and I used the kit paint to repaint to get a connection, I was getting off readings with multimeter.
The rear glass is easy to install.
I've messed around with broken defrosters on numerous vehicles over the years. I have had great success with the paint for the lines. For reattaching the tabs, about 70%. You have to heat the glass with a heat gun in about a 1-2' area before soldering the tab. A very hot iron is a must. Can't overheat the area either.
Then again replacing the glass on these trucks for under $250 isn't a bad way to go either lol
mattjones
VA
The repair wasn't covered under my carmax warranty and they wanted to charge labor for it, so I just bought the "kit" from them for $17 and did it myself. The "kit" is basically just a two part cement glue. Apply one liquid, then the other and attach.
You're supposed to let it sit for 24 hours. The first time I tried, I checked and the tab fell right off. I put more of the glue stuff on and let it sit for at least two days before I even tried touching it. I wasn't convinced it would stay there, but I reattached the cable to it and so far it's been about a month and it hasn't fallen off, and the defroster has worked. I'm still going to avoid touching it though. I think the key is to just be extremely careful and DO NOT touch it until you're sure it's completely bonded. The first time it fell off I thought the stuff was worthless and can see why a lot of people say it didn't work for them.
scottg918514
Yes, but didn't work for me. I just got this kit: http://www.frostfighter.com/frost-fighter-order-information.htm
And, reinstalled a tab on a 1 month old new piece of back glass the weekend. This kit seems better. I'll try the defroster in a couple days and report if the tab stays on.
Well, plugged it back in yesterday, sooner then I was hoping, but cold rain and snow and completely fogged up glass, so a good test.
It all worked great, tab still on (for now).
Ponchonutty
I don't believe its really a problem with the solder on the glass but that the cables going to the glass become hard, brittle, and stiff causing too much force on that solder joint.
scottg918514
Well, I stretched mine out before installing new glass in Feb. In March a tab popped off the new glass.
abright52
2011 Yukon Denali
Northern Illinois
Follow up:
So far the repair has been successful. This is what I used:
Loctite Rear Window Defogger - Tab Adhesive - 0.03/0.02-Fl Oz Kit
http://www.etrailer.com/Tools/Loctite/LT21351.html
I cleaned the area, applied the adhesive per instructions and held in place for a while. Then I left it disconnected for a couple days to ensure that it was cured. I stretched out both coils of wire to give some slack before reconnecting. Still holding after two months.
powerhaulic
adirondack mts
I warmed my glass with heat gun.
put a dab of solder on tab and a dab on glass
Put the two together and heated just enough to bond
good to go
andrewjles
