Tbruz
2004 Tahoe with 5.3 engine.
Longish stoty so be patient please.
Some background:
I'm a fairly decent home wrench and have performed brake replacements on about 75 different occasions and varied vehicles across many years ( family and friends) certainly not a professional though so I'm looking for some online advice /troubleshooting help here.
The current situation:
At first use the brakes perform perfectly.
After a rear brake job, using GM pads, new hardware, and having the GM rotors resurfaced by a very reputable machine shop I'm getting a weird rotational "thumping" when I apply the brakes at above 30 MPH. the new pads were bedded in by hard braking from 40MPH to 20 two times followed by 60MPH -20 two times .
The calipers were free, ie not stuck or sticking and the slide pins were removed, cleaned and re-lubed. wheels were properly torqued.
My issue:
At first use the brakes perform perfectly and are silent .
After about 15 minutes of use I can hear a rhythmic "thumping" at each application of the brakes. Its obviously rotational, heat related and coming from the rear brakes- NO shimmies or pulsating as you'd feel from warped rotors. I've taken everything apart again to see if anything obvious is wrong - all looks good.
I'm at a loss as to what to try next?
Thinking about replacing the new pads with the old ones(still have some meat left on them) just to see if the issue is still there and at least ruling out bad new GM pads.
Appreciate some suggestions as to what this issue can be
Next step I think would be popping for new rotors....even though these are non warped and within specs.
Thanks in advance
Tbruz
UPDATE with SOLUTION!
So i swapped back the old pads as I had them in hand still . Silent when cold but the same rhythmic thumping when the brakes heated up. I borrowed a runout gauge but could not get a clean reading seemed to be jumping.0008 to .0010 as the highest difference from being zeroed out on the face of the rotors; could not get reading off the backside so I moved on to swapping in new rotors....and back to the new pads I had installed yesterday- sanded lightly and re-bedded to the new rotors. PERFECTION! No thumping cold or after a good long spirited 45 minute run.
Thank you to all who helped with their guidance and suggestions- I truly appreciate the depth of knowledge and quick input I received from all.
Regards
Tbruz
Some background:
My issue:
Thanks in advance
Tbruz
Regards
Tbruz
