Rear End Alignment / Adjustment?
Scottydoggs
NJ
welcome to the world of the IFS front end. my 97 did the same thing as my 03. why you need to just rotate these tires and run at max psi to make them even come close to 50,000 miles of life.
I've got two KO2s wearing even and the other two have more tread on the outside edge compared with the inside edge.
We do a tread depth check at each rotation. Nineteen thousand miles and down to 10/32 at the lowest.
Started rotating them the way recommended in the owner's manual two rotations ago. Zero appreciable wear since last one, 5k miles ago.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Yeah i am certain the guy i bought truck from never rotated tires. Gd rotation will ad quite a bit of life to a set.of tires.
Sent from my SM-G925V using Tapatalk
Josejr00
