Rear end is shot
Bad bow tie
Grizz Straight FTMFW
Michigan/NC
No, they made the 14 bolt semi floater with 3.42 gears. It may be hard to find, but if you can get your hands on one, you are set. And yes, you can drive around in 2wd only with your gears different. Once you engage the 4wd with two different gear ratio's, you will shred your shit up.
C
CodyB4C
So all 88-99 semi floater with 6 lug rears will work? I should be able to find one then. What about breaks, will I have to swap them out?
Bad bow tie
Michigan/NC
88-98...99 was the NBS and that won't fit. Brakes should fit. It's a direct swap except for the u joint which you will need a new one like bowtiefreak stated above. Do you have pics of your truck up? I don't know if I have seen a 2 door police edition.
C
CodyB4C
Its really a ex border patrol car, nothing special just like a fleet vehicle with heavy duty steel wheels and a plain jane interior.
---------- Post added at 02:52 PM ---------- Previous post was at 02:50 PM ----------
Are the 2500 leaf springs a direct bolt in? It would be nice to have some beefy springs in the back.
Bad bow tie
Michigan/NC
I believe the springs do bolt in but you will need larger u bolts for them. Nice truck by the way. Where are you at? I found one in Michigan with 3.42 gears for $80...but i'm not sure what year it is. haha
Jrendon007
