Rear grinding sound driver side
Yukon2000xl
Hello folks ,on my Yukon xl 2000year I'm getting a grinding/metal rubbing sound from rear wheel when I hit a bumps at low speeds (no sound high speeds).Its not all the time but it is frequent and irritating.Ujoints were changed/driveshaft as well.I removed the parking brake pads both sides thinking they were scrapping.Rear brakes almost new,no loose in rear calipers or caliper brackets.No irregular wear on pads and noise is still there when coasting on brakes in an attempt to eliminate noise.
No vibrations ,no high speed sounds and it actually feels like something is clunking around back there once I hit a bump,like I'm jarring it loose ...what ever it is driving me crazy!!!
Could be a bushing in either upper or lower control arms or swaybar/end links.
Chip18
Dayton NV
Are you sure it's coming from the rear??? On our PT I had a rock trapped against the rotor, I looked and saw nothing but it kept making noise. I finally dropped the Caliper and discovered the problem. No harm in checking the front calipers.
Y
Yukon2000xl
Seems now that I turn right only the sound of grinding rubbing metal comes from left rear wheel no rocks in all dust shields
Chip18
Dayton NV
Hmm ... my grinding issue was a rock stuck between the Caliper and the rotor. You couldn't see it ,I only found it when I unbolted the caliper to see ... whatever???
But in anycase your situation does not seem brake related?? When you turn right it would load the right side and unload the left side. Grinding sound would be metal turning against something and banging would be something loose?? With a Banging sound my first thought would be a loose exhaust mount somewhere??
But that would not explain a "Grinding" sound?? At this point a good call would be to put it up on Jack Stands, remove all the wheels and take a flashlight and just look for sights of rubbing and pull and tug on everything that should be tight??
retiredsparky
If you are brave, support vehicle on jack-stands, lay under and check each wheel location with a stethoscope when another person runs vehicle slowly in forward gear in 4WD.
Chip18
Dayton NV
LOL that sounds like something I would do ... but not advise I would give. :)
In anycase I don't think that would help as the conditions would be "static." The issue seems to occur under load???
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Check your ebrake. I've seen where the shoes came apart and were just bunch of rust and broken bits sitting in the hat
He said he removed the parking brake pads on both sides.
AdamxYukon
