big_b_in_PA
Billy Badass
I am replacing the module on the rear hvac assy, and through different searches on google, I can't seems to find what the correct relearn procedure is. Does anyone know what it is, if there is one?
All mine did Before I changed the module was blow cold air, now I have hot and cold. It does get cooler when idling, but as soon as I give it a little gas it circulates warmer coolant into the core. I don't know if that's the same problem you have or a variable, but try taking the cover off the rear hvac unit and checking the hot / cold acuator, or try taking the acuator off and moving the blend door manually.
Good luck!
