rear lift gate or trunk door wont open
pvaldeben
Hi fellow tahoe owners. Loving my 2006 tahoe and this is the first problem I get since I've had it. the key fob does not unlock the rear trunk door or the glass door.
Can someone help me out with what parts to replace. I currently taking the cover off from a youtube video I found.
https://www.youtube.com/watch?v=xU6ybiY3F4I
I'm checking ebay and see lift gate actuator for $65 is this the part I need or not. The person in the youtube video seems to not be sure but said it could be another part.
Appreciate any help.
Heading back outside to continue to remove the plastic cover.
Thanks in Advance.
cybertek
South Carolina
A few months ago mine would not lock. If you remove the inside trim panel you can see the actuator. In my case I could see it trying to move when I pushed lock/unlock on the remote. You can also lock and unlock it manually by moving the actuator arm with your finger.
I bought the Dorman brand from Amazon and replaced it in about 10-15 minutes. It works great now.
witty_name
