donjetman
- Joined
- Oct 22, 2018
- Posts
- 1,752
- Reaction score
- 3,097
AWD Transfer Case Removed Today
Once the tranny cross member is out, the tail shaft of the transfer case can be lowered until it rest on the non-removable mid cross member. At the same time the engine oil pan comes close to touching the cross member under it. This tail shaft low attitude makes it easier to get the top nut loose(15mm crows foot) of the six nuts that hold the transfer case to the tranny, take the vent lines loose, and it will make it easier to remove the upper bolts/nuts that hold the tranny to the engine. To get the TC off the tranny, take the weight off the tail shaft with jacks under both the tranny and TC. The pictures show what type jacks I use. Smack the tail shaft with a dead blow hammer the TC will come loose from the tranny.
The tranny was working fine, so I'm NOT going to rebuild it now.
View media item 27396View media item 27397View media item 27398View media item 27399View media item 27400View media item 27401View media item 27402View media item 27403View media item 27404
