rear swap:00-06 in OBS?
Jaycenk
Florida
Will a 2000 to 2006 rear bolt into an OBS 98? I know the brakes will be different but besides that will it bolt up as far as springs mount to the same spots, shocks bolting up and sway bar mounting points? Also is it the same width?
Jaycenk
Jaycenk
Florida
Not even a 1500 truck chevy or gmc? I thought those used leafs?
---------- Post added at 12:53 PM ---------- Previous post was at 12:50 PM ----------
By the way Hotrod what fender flairs are on your yukon?
h0tr0d
Brenham, Tx.
I'd have to check out the trucks, I don't have one to compare it with. That might work if the springs are the same width and the shock locations are the same as well as the trac-width.
As far as the flares, they were on the truck when I bought it. I assume they're factory flares, but were painted body color. I had to sand 'em down and re-shoot them due to the clear coat peeling.
http://www.tahoeyukonforum.com/forum/showthread.php?t=15620
Jaycenk
Jaycenk
Florida
I may take a trip to a junk yard and see if they have the two laying around.
The_Bob
