Rear Wimndow Defrost not working
Rivieraracing
So what if there is no juice? Then what? Since the mirrors defrost, the button obviously works.
Good question, obviously with the mirrors working then it's not a fuse problem. If that was the case, then you would have to go from the plug on the rear window and work your way back till you found the problem checking for voltage and/or bad wires/connections.
JochenWoern
JochenWoern
Sacramento, CA
I guess I will check the connectors to the left and right of the window first, maybe the tabs connected with the defrost wire are corroded and do not make connection?
Rivieraracing
Had some free time tonight so I went out to our truck to check voltage of mine since it works great! Just remember, mines a 2002 so it might be different than yours but it should still have voltage at the tabs on the window with at least the window closed (yours might shut off power to it like it does to the rear window wiper to keep it from running while the window is open!)
So with my rear defrost switch on I was getting 10.4v at the passenger side power plug on the window and the drivers side I was getting .9v. Didn't matter if the window was open or not (which surprised me). I used the tie downs in the back as my ground (might take a bit of scratching around on the bolt head to make a good ground contact but it did work) and obviously used the positive end on the tabs on the window.
Let me know what you come up with!
shadoow98
Hi I had the same problem I would hear the "click" but no heat at all. What I found out for my problem and I don't know if it would work also for you but it was the rear window not getting a good negative connection.
Here is my post with my fix
http://www.tahoeyukonforum.com/forum/showthread.php?t=56248
Its just running a wire from a metal part of the rear door to the driver side pin of the window defroster.
JochenWoern
JochenWoern
Sacramento, CA
So, finally got around to measure and had approx. the same voltages as above and determined that there is no voltage problem.
Guess the only issue now could be that there is a break in the heater wire accross the back window?
Rivieraracing
Well it may not seem like it but consider that a blessing because now you know it's a problem at the glass instead of having to do additional investigating and diagnosing! If I get a chance tomorrow, I'll unhook both wires going to the glass and see what I get for ohms between (if that even matters at all) and see if they compare!
Thanks again for the seat heater diagram that you emailed me, I need to make some time and get my seat figured out before its too late and warm out!
JochenWoern
JochenWoern
Sacramento, CA
Your welcome Chris, my pleasure.
TheSwede
Sweden
I had my rear glass blewn out yesterday......it was on the yard not driven in several hours . +15-20 C. I'm thinking i had some kind of a short on the passanger side. So i hope My dealer can find out what went wrong when they replace the glass.
joltman
Castle Rock, CO
So, I've discovered my rear window is not defrosting. I've never heard a click when I press the defrost button. And it hasn't been cold enough for the side mirrors to get iced, so I have no idea if the button works at all.
Looks like I need to compare both wires to the window for voltage. I should ground to the truck and not but the voltage meter between the two wires?
Would you be able to see a bad heating wire on the glass? Thanks for the help (and sorry to hijack the thread!!)
Justinj360
Did you ever check your rear defrost fuse under the hood? Your problem sounds exactly how mine is when it's blown. It goes out often. Not sure why
Brettwesenick
