rear windows rattle
jimr5454
My windows when down half wayish rattle a little I would like to find a way or stop that any sigestions? I know don't leave them half down ..lol but I'm hoping there's a product or a suggestion for this .
gibbygsxr
Kingston, NY
I'm in for an answer. Bugs the s#*t out of me. 52k for wobbly windows. Going to have them check it at the next service.
jimr5454
jimr5454
Did you have them checked out and if so what was the response, ?
fiatdale
Houstons Best
Houston
Rear window regulator only has one mounting point to the glass. They have always had a lot of slop in them when rolled down. Not sure if there is any solution.
PlatinumYukon
Naperville, IL
I had the same problem with my Left Rear window on my 2012. It wound up being a poorly manufactured window weatherstrip on the top of the door on the outside. It is a weatherstrip that is supposed to push against the window to prevent water entry and rattle. Had the dealer replace under warranty. no more issues so far. Hope this helps. :)
jimr5454
jimr5454
I resolved my issue .i took panel off and i studied everything i saw and found nothing out of order but i then noticed when i took off lower window stripping and noticed the metal that it was mounted on might be bent a little away from the window i have dogs and thought maybe them or the kids pulling and pushing the windows in and out the metal strip that they are mounted on were bent. . I bent them in a little and the rattle is gone ... so if was difficult being careful not to break window but we'll worth it..solid sounding door when is being closed. .
John18A
