Resolved - Rear wiper arm quit - help with removal
thefrey
Title says it all
This is what is left - which I believe to be part of the old wiper assembly. Do I need to get the nut thing off to get to the splines to install the new wiper? 2013 Yukon XL if that matters
wjburken
Eastern Iowa
Title says it all
Yes. If you don’t have a puller that fits/works, I’d take a dremel and cut the length of the “nut” on 180° from each other so you can remove it.
thefrey
thefrey
HUUUGE! Ended up using an oscillating multitool with a metal blade and some patience not to knick the threads. Worked wonders, thanks for the recommendation! IMG_9024.jpeg
wjburken
Eastern Iowa
Steadyj
