Recirculation Actuator
djtoothowd
arkansas
ok so when i bought my Tahoe (in the Winter) the A/C blew cold and i was told it had been redone last summer. well summer is upon us and wouldnt you know it the damn A/C dont work. i recharged the system with our A/C machine here at work and it didnt help. i jumped the low side switch and still nothing. i took it to have it scanned for codes and found B0229 had been set so i bought a new actuator and replaced it and it still doesnt work. i was hoping maybe it just needs to be reset/calibrated but i cant find out how to do it anywhere. does anyone know how? and if this doesnt fix it what else could it be?
also this may be a dumb question but are both the high and low side service ports on the same line? i can only find 2 and they are both on the high side line to the accumulator about 6" apart from each other. they are 2 different sizes by the way.
bkboatnsleds
McHenry, IL
Here is what I can find..
Place the ignition switch to the OFF position.
Connect all previously disconnected components.
With the Mode knob in the PANEL position, press and hold the AC button for 5 seconds.
Rotate the Mode knob fully counterclockwise.
Rotate the Mode knob fully clockwise.
Release the AC button.
Wait 40 seconds for the HVAC control module to self-calibrate.
Start the vehicle.
Jongrreat
