mountie
- Joined
- May 9, 2018
- Posts
- 5,414
- Reaction score
- 10,230
Nice to hear I should be able to remove the sun 'shade'... I'll look into that.
The lower pic is your Onstar mic, other is I believe an aspirator or thermostat for the HVAC. The rear HVAC panel just slides out, it has a tab in each side so if you slide a small flat screwdriver on the side it pushes the tab in to release it while you pull back on the panel.what are these two things about?... the one us under driver side visor. the other clipped to rear hvac controls.
also how do you take off the reat hvac control pannel?![]()
Sent from my SM-A505U using Tapatalk
If you are talking about the whole "pod" that the rear hvac controls and map lights are mounted in I believe mine had a screw in the front, right by the arm for the rear view mirror. Once that is removed it just pops out.also how do you take off the reat hvac control pannel?
He said the rear panel, not the one up front by the mirror.If you are talking about the whole "pod" that the rear hvac controls and map lights are mounted in I believe mine had a screw in the front, right by the arm for the rear view mirror. Once that is removed it just pops out.
Fore & Aft
Bow & Stern
Port & Starboard
