Refrigerant capacity?
domoarigato
Hey guys
Does anyone know how many lbs of r134 the PPV's take? I believe all of them do not have the separate rear AC controls.
I've found numbers anywhere from 1.6lbs to 2.7lbs, not sure what to follow.
Thanks!
D
domoarigato
english-french-refrigerant-warning-lable-gm-part-1.jpg The under hood label should look similar to this one, the amount differs from each vehicle, good luck.
David g...........:)
I looked but didnt see anything, I will take a picture for you guys later. The only sticker I found said to use r134a PAG and not the other.
JDGnut
TX
hope that helps. that's from my 2011. looks like 1.130kg sorry for the crappy photo
Do you have dual air? My tag on my 2007 is mostly missing and I can not read the capacity of the AC.. I had it over changed, and just pulled it out to weight it back in and can not find the capacity.
Thanks
JDGnut
TX
I think I finally found it... and it looks to the be the same as your tag.. 40oz.. (2.5lbs.)
992dr
Eastern N.C.
Random question. How often do you need to recharge your a/c?
Thanks
apacheco93
