Remote Start and TPMS
CHASER32
Boise, ID
Need a little direction. I have a 2007 Tahoe LT factory - After a lightning storm, the next day the remote start and TPMS stopped responding. Did a little reading and my conclusion is that the module burnt out or was otherwise affected by the storm. What I cant figure out is exact location of this part. The dealership quoted me around $1800 for diagnostic parts and labor. As much as I like burning money, would like to try my hand at it. I know it will need reprogrammed, no worries there. Can anyone tell me where the module is?
See if this is helpful to you.
Remote Control Door Lock Receiver
Part Number:
20803735
gm.pngGM
Other Names:
Tire Pressure Monitoring System Receiver
Replaces: 15857831, 15946938, 25808837, 25852909, 25855007, 25896497
Description: This part requires programming and/or special setup procedures GM Service Information describes the procedures and special tools needed... More Info
MSRP $256.40
$142.30
The Remote Control Door Lock Receiver - GM (20803735) is typically located behind the dashboard of the truck, usually near the driver's side footwell; it's part of the vehicle's electrical system and receives signals from the key fob to lock and unlock the doors.
Key points to remember:
  • Access may require removal of panels:
    To access the receiver, you may need to remove plastic panels around the dashboard or under the steering column depending on the specific vehicle model.
  • Consult your vehicle's manual:
    Always refer to your truck's owner's manual for the precise location of the remote control door lock receiver as it can vary slightly between different models.
well unless lightening actually struck the vehicle it's unlikely it had anything to do with it.
but hey anything is possible
it's also worth noting that tpms and remote start have nothing in common. i.e. tpms light will not prevent a autostart, but a check engine light would.
have you tried something basic like disconnecting the battery for a few minutes? if there was a electrical disruption this could cause a bad handshake between modules
and disconnecting the battery for a few minutes could re-initiate a good handshake and resolve a problem.
Pacdad
