Remote Start Troubleshooting - SOLVED
Awesome! But since they show part numbers for the 2 speed xfer module, possible original 1 speed modules can't be reprogrammed to 2?
But angry because they gotta screw with us little guys trying to program our own modules they made this stupid way..
Ideally, I'd like to get the VIN of a truck with the MP3010 and see what programming options are available to it.
The NP0 wasn't available in 2009 and my other two also have the MP3023.
DaveO9
DaveO9
Vancouver, WA
I'm pleased to report back that @mikez71 suggestion of trying out a new Dorman TCCM worked! New module installed, did the learn procedure, and everything's working - all T-case modes AND REMOTE START!!! Thanks to Mike and everyone else for the help. Sorry this was such a wild goose chase.
We may not ever know the whole explanation as to why the module worked fine for its function, but prevented remote start. There is one small possibility.... the Dorman module had a sticker over the connector ports saying to "four- pin connector must be connected last to avoid communication errors." (Four-wire connector is the one that supplies power to the module) I did not know that rule when I did the t-case conversion, so it's possible I toasted a circuit or something inside the module.
Just remember that most of the Dorman stuff (as bad as the electronic stuff can be) has a lifetime warranty. Every once in a while they do score some points.
j91z28d1
that's awesome it worked.
the wild goose chase is a good thing, I learned some stuff from this thread and I'm sure others will too.
mikez71
I learned alot too! Let's go TYF!!!
Only threw the dorman suggestion out there because I was out of ideas..
It may not have been caused by the '4 pin connector' since you had no communication errors.
Super glad you have it squared away.. You know what to do now.. (SOLVED!)
DaveO9
DaveO9
Vancouver, WA
OK, I give, how the heck do you change the thread title? i know I've seen many do that, and I think I've even done it myself, but now I'm not seeing the button or link to "edit thread"
I believe the option to make changes to the title "times out" you could ask @Fless to make a change, admins have the option to edit
Filvanz
