Remote Start Troubleshooting
j91z28d1
gm makes and has calibrations for "upgrades" you just have to message with them and tell them what you are trying to do, you need a paid vin of course and the part number of the module being added.
obviously they made these with different trim levels, so all they have to do is edit the calibration file they provide (upon request) to work with your vin.
all they have to do is look up the part number being added, find the associated calibration file. attach your vin to that file and save it.
then they just give you the calibration file number that you enter into sps to program your vehicle
that's my basic assumption of how that works, I do not know if they charge "extra" for that or not.
I know it can be done because there are gm service bulletins on "how to" that have been provided to dealers when dealing with upgrades
I didn't know this until after I had tried the radio upgrade and started looking into why it didn't work like I expected it to and that point I just said f-it I already was past doing it and made something else work.
I had no idea they would do that for you. that sounds like what it would take.
almost sounds to good to be true. gm isn't usually very helpful. what phone number would you call for something like that?
there should be a technical support phone number for techline or a option to message or email from your account
i know that once you do a calibration it gives you a case # and related information if you have a problem afterwards
1-800-828-6860 I would imagine support is for paid vin slots and they likely are not going to just answer random questions but I could be wrong.
probably going to need a account number when calling
j91z28d1
maybe worth a call with the case swap. tell them what you got and what you need. by scanning a working 2 speed truck and get the software #.
can't hurt to try. amazing if it worked.
DaveO9
DaveO9
Vancouver, WA
Yeah, I'm going to have to think on this one for a day or two. Talk of bricking the whole thing does cause a little concern for me. :) Another concern I have is using my Chinese Tech 2 as a pass-through. I could just see there being some kind of GM prevention for that kind of thing.
Starting to wonder if aftermarket might be the way to go. This unit seems promising: https://fortin.ca/en/products/evo-rs-t-harness-included-kits/evo-gmt4/ Before buying I would try to get some clarity from them if their system would be affected by the ECM crank abort flag I'm seeing. (To answer your earlier question - yes, the whole problem comes down to the T-case swap. For some reason, the new TCCM is causing an ECM crank abort)
Is it even worth trying a local dealer for this? I'm guessing they would have to go through the same thing with tech support and getting a special upgrade calibration.
janabanana
