Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
If it's the 2 piece console that has the front extension you unbolt the extension from the console by removing the drink cubby drawer and removing the bolts? Inside from the extension. Then you unbolt the 8 nuts/bolts from the seat tracks and lift them off the floor which will let you remove the console.(or if you want to remove it from the mounting bracket, just open the console lid and remove the 4 bolts on the floor of the console. That will remove the console from the mounting bracket.) The front extension I believe you remove the "face" to gain access to the bolts holding it in place.(I'm not 100% sure since I don't have that piece.)
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
