Removing front and rear Chevy emblems...
adamwbagley
Any chance someone knows of photos or a video removing the emblems. I'm coming up short on here and YouTube
16blkltz
I can't find any for rear emblem, but here's an easy way to remove front emblem (if your hand/arm can fit through top opening):
chicagofan00
Arizona
It's super easy! Front has a couple of clips you pop out from behind the emblem and the new one snaps right in it's place. The rear one is just like taking off any other badges on a vehicle. A little bit of heat from a heat gun or hair dryer and some floss or thin fishing line and you are good to go. :)
StealthTX
The video above shows how to remove the front bowtie...I swapped out mine the same way, but didn't have the tools he showed and got the same results with the flat end of my kids Lego brick separator along with an old gift card.
For the rear it's just 3M adhesive so I used masking tape on each side of the bowtie and on the top to show the outline/positioning of the emblem. After that I removed the emblem with fishing line, then used an eraser wheel to get off any adhesive left over, and finally wiped the area down with an alcohol pad. Since the outline of the emblem is already marked with the masking just line up the new one and press it on.
The whole process front and rear took me all of about 20-30 minutes and came out looking perfect. Overall it's a pretty simple and straight forward mod, just take your time and don't rush yourself!
airidane
