If you have a Volt meter or DVOM or test light I would check what wires are live and what are dead. I would follow each wire to the dash if you cant trace it anymore I would cut it and cap the end (Closed End Crimp Caps).Just an update I got the center console dismantled. All it was held together by screws along sides.
I’m left with a mess of wires that seem to run up under dash. Does anyone know how I can go about getting to other end of wires?
Center console check Craiglist, offerup, and car-par.com Facebook market place. search tahoe, yukon, silverado (2007 was a in-between year 2008 to 2014ish), sierra (2007 was a in-between year 2008 to2014ish), avalanche (2007 to 2014 only) Escalade center console will fit but you have to swap everything dash display and vents climate controls (wiring involved and radio (Reprogramed to your vin number to work and maybe wiring).
By in-between years some are on the GMT800 you can tell by the front end and dash.
Check the Wiki for GMT900 https://en.wikipedia.org/wiki/GMT900
You found one of my old post, it is a direct fit our center dash sticks out more then the truck model see attached photo it is more common for a Jump seat then a full console in a truck and a SUV (attacked both consoles), you will need to cut the airbag cover a little sometimes they bolt in fine some you need a little trimming. Make sure you take the airbag cover off before cutting.I thought I would repost this here since good info. My question please is are there more specifics other than year of these models? I've seen a couple youtube videos where this happens, the dash has a gap at the end, not flush with vehicle. Here is an example apparently the issue is this LT Silverado owner bought a LTZ console: 5:18 mark
I have a harbor freight multimeter but never used one before. Any advice on how I go about doing this?If you have a Volt meter or DVOM or test light I would check what wires are live and what are dead.
There is videos on YouTube, Most you are going to run into is 12 Volts, 1 to 5 volts, and grounds.I have a harbor freight multimeter but never used one before. Any advice on how I go about doing this?
