Roadtested
- Joined
- Aug 28, 2021
- Posts
- 9
- Reaction score
- 2
I just replaced the driver side switch control module with a Standard Motor Products DWS394 Driver-Side Power Window Switch (with Power Folding Side-Mirrors and Adjustable Pedals. ) Aside from the fact that the driver's window is still inoperable, now the drivers mirror has to be adjusted every time, the driver 1-2 memory no longer works, and the pedal adjustment doesn't work. I don't really need the driver memory or the pedal controls but IMO, they should work as designed. I'll need to check the driver's side window motor and replace that as needed. My question is - has anyone used this switch module before?
Essentially, I want to know if anyone has similar experience, suggestions and if I should send it back to Amazon while I still can.
