Replace Liftgate Fuse HELP!!
skyhighsami
I did a complete interior swap from the cloth SLE interior to the complete SLT interior. Wiring harness, leather seats, signal mirrors, console EVERYTHING. Anyway since then on start up the REPLACE LLIFTGATE FUSE comes up and I can not find any info on it. How do I clear.
skyhighsami
skyhighsami
Anyone I have searched the net with 0 success.
petty144
liftgate fuse
I have a 2005 Yukon XL with the same "replace Liftgate fuse" message, I have looked everywhere and cannot locate it. I will keep looking.....
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
I would start by making sure the rear wiper has a good ground since there was a TSB on that.
then i would check the wiring to the gate for frayed insulation, particularly where it passes thru grommets or folds or moves etc.
then I would see if there isn;t a module in the liftgate that runs the wiper like there is on the TBSS, which also gets the same message.
What doesn't work in your liftgate?
petty144
fuse
I FOUND IT!!!!!!!!!!!! YEA!!!!!!! It was an interior fuse box located on the left side of the dashboard and the fuse was labled ECC 10A.
Eagle
EL PASO, TX
Excellent!
skyhighsami
skyhighsami
Tried that but it didn't fix mine.....damn it
godsend1
This fixed the message on mine as well. The fuse also controls the rear HVAC. 2006 Tahoe
Thanks
hwood
skyhighsami did you ever figure out your problem with the message??? I have same issue any help would be appreciated..
Vettexan
