100k is there rated lifetime, typically they should all 4 be replaced at the same time.I am working on my 2019 Tahoe with 122k miles. I have my exhaust pipe out and all four oxygen sensors are staring at me lol. Should I pro-actively replace them? I don’t have any codes but it would be pretty easy now.
I don't disagree per se - just suggesting options based on the likelihood that the rear O2s may not need changing nearly as urgently as the fronts.IMO, if you have the easy access and are gonna keep the vehicle, change them all. It's only money.
it's just a preventitive measure, if you want to maintain your vehicle and not get slammed with all kinds of needed maintenance later when you may not be prepared to fork it out.I don't disagree per se - just suggesting options based on the likelihood that the rear O2s may not need changing nearly as urgently as the fronts.
