jkssv08tahoe
- Joined
- Jan 5, 2018
- Posts
- 57
- Reaction score
- 53
I have a 2008 Tahoe Ex-police truck. I had to recently replace the fuel pump on the truck. 142,000 miles on it. I had dropped the tank and had more then 1/2 a tank of gas in it. I was able to get a siphon hose done the fuel neck to get gas out so I could have a light tank to install back into the truck. After I did this I am now having a issue with pumping gas into the truck.
As the gas goes in it keep coming back up the neck and splashing back out. Almost like there is no vent line. Or something is clogged. I had ran the tank back to 1/4 tank and just dropped the tank again to check all hoses and wanted to check in the neck. There is a metal piece/part in the fuel neck that pushes up and down. I thought maybe I screwed this part up when I pulled the Siphon hose back out. But this metal piece/part moves freely and all lines are connected and nothing looks pinched. I even blew some air through it.
What could be the issue?
Thanks for any help Jason
