Replaced Head Gasket/Won't start
B
BDoolz
Not sure I know what ~20BTDC is. I know what #1 at TDC on compression stroke is.
Nevermind, figured it out 20 degrees before TDC, stab distrib in order to create a mark on the bottom to align properly. So my question to that is will that not damage the tab for the oil pump? Or is it far enough below to not make contact?
Tehboogyman
Make the mark just below the cap under whatever terminal you're using as #1. Then pull the cap off when you stab it so you can rotate the distributer until the rotor is lined up with your mark.
Tehboogyman
Make sure after you stab it to rotate the motor until the distributer seats on the oil pump driveshaft and drops all the way in. Don't try to tighten down the distributer if it's sticking up above the manifold, it's most likely not seated on the driveshaft and you'll bend it.
B
BDoolz
Got er going, I was about 1 tooth off, fired right up. Thanks for the help. Now x fingers for no leaks!
B
BDoolz
And by the way incase anyone else happens to see this post looking for info. My mistake was that the #2 terminal on the inside actually comes all the way across and lines up with #1 port, and the number 1 runs down clockwise of the port. So #2 was firing instead of #1. Rookie mistake!
SunlitComet
OBS Jedi-Do Good
unknown at this time.
i would say timing issue then
that motor has hydraulic lifters to no valve adjustment needs to be done just make sure the rocker arm bolts are all torqued to 22lbs
a valve adjustment is required because it gets out of adjustment the moment you start to remove the rocker arm NUTS to remove the rods to remove the....
62LRST
